TwinTurbo.NET: Nissan 300ZX forum - Disagree. Far and above, the 2 biggest factors in mileage
zellamay
on November 13, 2011 at 4:37 PM
It has more to do with the efficiency of the engine...
posted by -Grimm-
on November 13, 2011 at 02:15 PM
are engine size and engine rpm. One could keep the mileage pretty close after going to a lowered diff ratio, but you'd have to take care to shift at low rpm. The idea that you would get better mileage just doesn't make sense to me.
tt swap to na differential
sonnymarton
20:59:48 11/09/11
Re: tt swap to na differential
sonnymarton
21:30:29 11/09/11
everything
thumper
23:02:54 11/09/11
Re: everything
sonnymarton
23:10:18 11/09/11
ZIP
MidLifeZ (DFW)
06:25:57 11/10/11
Re: ZIP
sonnymarton
07:19:53 11/10/11
It's math. Compare gear ratios to get a rough
zellamay
08:07:10 11/10/11
Re: It's math. Compare gear ratios to get a rough
sonnymarton
11:52:35 11/10/11
The ratios are 4.08, and 3.67, so if you divide them out,
zellamay
14:52:25 11/10/11
and losing 2 MPG is way worth it for
MidLifeZ (DFW)
07:19:21 11/13/11
and losing 2 MPG is not worth it for
zellamay
13:01:31 11/13/11
-Grimm-
14:15:12 11/13/11
Disagree. Far and above, the 2 biggest factors in mileage -
zellamay
16:37:09 11/13/11
